Results 1 to 10 of 17
Thread: What’s person suppose to do?
    Long story short I did not pull my 69s off the track soon enough. It got customized by an Alfa as seen here. https://www.youtube.com/watch?v=pX8r5ZyHvGw (Think you don’t need a Hans?). So here is my dilemma. It’s a numbers matching car per CoA. The engine is the last 69S listed in the technical manuals it was born on 7/30/ 1969. The engine is not in the car it’s at my house as is the original transmission. (Never used as a track engine) but is in pieces. I’m not going to stop racing and have a 72 T that I can put all the track stuff on. I have most of the original pieces front struts, torsion bars, sway bars, heads, pistons, Mechanical injection, front oil cooler, etc. from the 69 except for the windshield . Car is repairable but to get it back on the track will take me too much time. So the issue is to try and sell it with the engine and transmission or I can part it out probably get more dollars for it. So should I offer it all together or just part it out?????
    Mar 2006
    Louisville KY
    I hope your message box is empty.... I would sell it all together as a project.
    Tony Proasi
    52 split window coupe
    Apr 2008
    Virginia's Blue Ridge
    First, glad you got through that incident in one piece! Quite a shot you took. Regards your question, I think there's too much value as a matching numbers project. Don't part it out.
    Good luck with the sale and future racing endeavors.
    That was hard to watch. Truly glad you're OK.
    Peter Kane
    '72 911S Targa
    I was sent this clip awhile ago by Lars.......
    It's still a shock, and hurts my gut to watch it....
    I'm SO GLAD you're OK, and can be talking about it...
    Good luck on whatever comes next....
    Wow..makes the NFL concussion story seem like flag football. Best of luck. Maybe it's time to take up tropical fish.
    Senior Member mohrgan's Avatar
    May 2011
    Upstate NY
    wOw!!! Glad you are OK after seeing that! Best of luck on what you decide to do with the car!
    -Chris Mohr
    S Registry #1978
    Banned
    Nov 2004
    Scottsdale, AZ
    Wow is right.
    That last split second is sheer terror, right before you know the inevitable is coming. Glad you're ok.
    Saw that one coming; it looked like you tried too many times to "fix" your original oversteer dilemma.
    Are you still doing track events?
    The car is definitely worth more if sold complete. The best of luck to you.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Sell it all as one lot.
    Very glad to see you survived that.
    1969 S Coupe #761
    Early S Registry #1624
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Quote Originally Posted by MJHanna View Post
    It got customized by an Alpha as seen here.
    I think you mean it got customized by an Alfa, unless you were referring to the driver.
