Thread: Adjusting H1's
    Jun 2003
    Bend, Oregon
    Adjusting H1's
    One of the attractions of H1's is that with two bulbs and two reflectors they enable the low and high beams to be adjusted separately. When I restore them I afix a reproduction of the instruction label for adjusting the headlamps which looks more or less like this:
    A C H T U N G
    Erst Abblendlicht einstellen, dann. Fernlicht korrigieren
    Kennzeichnung der Stellschrauben auf der Streuscheibe:
    Abblendlicht mit "↔️A" u. "↕️A", Fernlicht mit "F↔️" u. "F↕️"
    Translated into English:
    A T T E N T I O N
    First adjust dipped beam, then correct high beam
    Labeling of the adjustment screws on the trim ring:
    Dipped beam with "↔️A" and "↕️A", High beam with "F↔️" and "F↕️"
    Looking at the headlight the adjustment screws are arrayed as follows (with the locations conveniently marked on the lens with letters and arrows):
    Low Beam : Large Reflector
    A: Upper right corner - adjusts up-down
    A: Lower left corner - adjusts left-right
    High Beam : Small Reflector
    F: Upper left corner - adjusts up-down
    F: Lower right corner - adjusts left-right
    Piece of cake.
    Cheers,
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Here's a visual from the factory manual
    SL30
    Name:  H1 lens SL30.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Jun 2003
    Bend, Oregon
    Thanks for posting that. What is the date of the publication? I'm curious because it's the older style lens with the larger prism.
