Results 1 to 9 of 9
Thread: Pistons/Cylinders
    Senior Member sebastianroher's Avatar
    Jan 2015
    Florida
    Pistons/Cylinders
    Looking for a set of pistons and cylinders to convert my 2.2 to 2.5. If anyone knows a good place to pick up a set or has some, please let me know. Thank you.
    1971 911t coupe
    2002 Camaro z/28
    Mar 2004
    Castro Valley, Ca.
    do you perform this mod w/ larger pistons or a 70MM crank ?
    1940 Mercury town sedan
    Larger bore.
    I have a friend with a set of almost new 92mm Mahle RSR pistons and cylinders. Bought from Andial, in the original box. I talked to him today and he said he is going to sell them. If you are interested send me a pm and I will get you his contact info.
    Jan 2015
    Florida
    Quote Originally Posted by 913 View Post
    pm sent! Thanks
    1971 911t coupe
    2002 Camaro z/28
    I believe the 90 mm RS Pistons were used to build up to the 2.5 motor...
    Peter Kane
    '72 911S Targa
    RS pistons with short stroke crank has too low compression. I think you will need JE or other aftermarket pistons.
    Jan 2015
    Florida
    1971 911t coupe
    2002 Camaro z/28
    Nov 2003
    Santa Monica CA
    the real 2.5 set up is Mahle 89 mm 10.3: 1 compreeion with 66mm crank. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
