Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 154
Thread: MY 1970 911E Restoration Project
  1. #131
    May 2006
    CT
    Hi Tim
    I never really got the rear bumpers/license plate panel to align to my liking. I went round and round and spent way too much time on it. I did all I could to shim, bend the mount brackets etc. In the end, the car will go back to Auto Associates to have the antennae and fuel door mechanisms installed as I do not want to dismount the door. I will have them realign and touch up the rear as well.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  2. #132
    May 2006
    CT
    I completed my DIY four wheel alignment and ride height adjustment. I will call this preliminary so the car will be safe to drive when the roads finally clear here in CT. I used my trusty old Ray Scruggs process that has served me well for past alignments. I used jack stands, some yellow thread from the sewing kit and my right angle camber "gauge". I followed the factory process for checking caster with +/- 20 deg steering angle camber measurements. I also used some bungees as a DIY steering lock while adjusting the tie rods for front toe.
    I has initially set the spring plate angles at 34.5 deg. I ended up with a starting ride heights (measured at the fender lip) of 25.8" front and 26" rear. Although this may be close to the factory ride height of the day, I wanted something a little lower. Realizing I would get some settling as the suspension settles, I set my targets at 25" front and 24.5" rear and about 1 deg of rake measured on the door sill. I had to re-index my front torsion bar levers to lower the front and went through the re-indexing of the rear torsion bars and spring plates to get close to my targets. My final results were 25.1" front and 24.8" rear with 0.5 deg of rake.
    Following the process described by Scruggs, I was able to set the front up to 1 deg of negative camber, 5.5 deg of caster and 0.13 " of toe-in with the rear at 0.7 deg of negative camber and 0.0" of toe.
    I think the car looks better at this attitude and I can't wait to drive it.
    Tom Butler
    1973 RSR Clone
    1970 911E
  3. #133
    Senior Member joegt3cup's Avatar
    Mar 2004
    Colebrook CT
    Looks great!
    Joe Annicelli
    Early 911S Registry #751
    Polo Red/Black 1967 Porsche 911S Coupe "Walter"
    Black/Red 1967 Alfa GTJr. Coupe "Nero"
    Italian Red 1994 Ducati 900SS/SP looks fast standing still
    Italian Red 1957 Gilera 150 Sport
    Ahhhh the sixties... I envision myself one early Saturday morning wearing plaid shorts, black shoes with white socks smoking a cigarette heading to the hardware store to buy a bag of nails.
    SWB cars are an acquired taste however once acquired theirs no turning back.
  4. #134
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    Really does Tom, nice work.
    Quote Originally Posted by joegt3cup View Post
    Looks great!
    '72T Coupe - Sepia Brown
  5. #135
    May 2006
    CT
    Well, the weather and the roads finally cleared up enough last weekend for me to get the car out for some shake down drives. The car seems to drive really well. The engine pulls smoothly through the rev range in all gears with no backfires or hesitation. The idle is a little high at 1500 RPM. I expect that to be a simple adjustment. The turn signal cancel does not work but I hope that will respond to a little cleaning and lubrication. Other than that the car seems just great. I am very happy with it.
    Tom Butler
    1973 RSR Clone
    1970 911E
  6. #136
    May 2006
    CT
    For anyone who might be interested, I posted the details of the engine build on the Pelican Engine Building site.
    http://forums.pelicanparts.com/911-e...d-project.html
    Tom Butler
    1973 RSR Clone
    1970 911E
  7. #137
    May 2006
    CT
    Another update. Since my last posting, the car went back to Auto Associates for 4 wheel alignment, ride ht and corner balance, final MFI tuning, installation of the antennae, fuel door, rocker deco and some adjustments to the rear bumper/license plate panel. I have put almost 700 miles on the car and I am very happy with the results. It drives and looks like it just rolled out of the factory. A couple of surprises included the failure of the rebuilt CDI box after less that 600 miles and a sticky starter solenoid that required replacement of the rebuilt Bosch starter. I am starting to think about my next project, possibly a 914-6 GT hot rod.
    Tom Butler
    1973 RSR Clone
    1970 911E
  8. #138
    Looks great Tom. Look forward to seeing some glamour shots out on a country road somewhere
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  9. #139
    Nov 2003
    Santa Monica CA
    Love Bahia Red nice job with the resto
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
  10. #140
    Love seeing threads, like this . . .
    . . . always inspiring to see someone carry a project through --- especially from where you started!
    Thank you for taking us along!
