Results 1 to 10 of 10
Thread: Fuel tank breather setup for 1969
    Feb 2005
    Lake Tapps, WA
    I'm looking for the correct fuel tank venting setup for a 1969 911. Any photos or description would be a huge help.
    It sounds like the terminal vent house dumps out behind the drivers bumperette.
    Am I also correct that there is no charcoal canister in 1969?
    Does the brake fluid reservoir vent line connect into the fuel vent drain tube or does it exit the chassis separately and if so, where?
    This photo is from a 1971 911T I believe and is not correct for 1969 but might be of good reference for someone.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by endo911rs View Post
    Correct.
    Correct
    Yes it connects to the vent drain tube at the plastic "y" connector shown above in your picture.
    For 69, the system is very simple. One line from the tank to the vent box under the cowl, a second line from the vent box to the "y" connector, and then a continuation of the vent line to behind the washer pump/reservoir overboard
    1969 S Coupe #761
    Early S Registry #1624
    Feb 2005
    Lake Tapps, WA
    Where does the small end of the "Y" go? It looks like it points up towards the brake reservoir...
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Aug 2009
    Atlanta
    Small end of the Y takes the brake reservoir overflow line.
    Another thread:
    http://www.early911sregistry.org/for...ilation-System
    1969 S Coupe #761
    Feb 2005
    Lake Tapps, WA
    Great, that makes it easy! I'll post a photo when I get it completed.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Not sure if this is 100% correct, but this is how my '69 turned out after cleaning up and replacing the tubing.
    My tubing only had one of the "Y" connectors as shown in your first post. Beh's post shows the rest.
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    This is what came out of my '69.
    Cheers,
    Ron
    Oct 2010
    Southern Ca.
    Screws for the filler neck hose clamps should face the trunk compartment .
    Feb 2005
    Lake Tapps, WA
    I was just installing those! should the screw be on the top or bottom?
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Oct 2010
    Southern Ca.
    The screws are oriented correctly - slots facing up , but the clamps should be pivoted on their axis so the screw body is on the trunk compartment side of the hose .
    I think Porsche did not want the screws interfering with the hoses and wiring , and it's easier .
