Thread: FS: 1969 911S restoration project
    Last edited by 72targa; 09-19-2015 at 06:06 AM. Reason: Rearranged so as to easier find price...
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Would you mind sharing the VIN, engine number, original color, options, etc?
    Perhaps give more of an explanation of how much of the car is still there?
    Difficult to tell in the pictures...
    1969 S Coupe #761
    Early S Registry #1624
    Vin 119300605
    The original car colour is silver and it has been painted one time. All the subsequent paint work is in either epoxy or urethane. The car was a driver when purchased however, the synchros were worn and the car popped out of first and second gear. I replaced the transmission synchros and did a engine reringing. I had the case machined for lay shaft bearings, new bearings throughout, new timing chains but soda blasted old pistons..... with fresh rings. Heads bead blasted, fresh guides and valves......
    I have more or less everything for the car plus many new items. The front seats are poor to fair and the car will need a complete carpet kit. I also have a new windshield
    The car is located near Guelph Ontario Canada
    Jul 2014
    Niagara, Ontario
    I will be back in Ontario this coming week, please contact me via PM or direct... mike at autosport canada dot com to arrange an opportunity to see the car. I'm in Niagara.
    Mike
