Thread: Leak at bottom pulley
    My 2.2E has a leak at the rear of the engine at the bottom pulley, crank.
    Is there a rear seal here that can be replaced with engine in the car, removing ins, tin, motor mount and pulley. If so anyone have a part number as well.
    Any reference articles would be great as well.
    Thanks in advance
    Restoration newbie.
    Jun 2007
    San Francisco
    There's a seal at the pulley end of the crank. Pelican lists this part as 999-113-290-41-M204
    I've only installed this with the engine on a stand, it seems like it should be possible to do it without dropping the engine.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Sweat thanks
    Feb 2011
    Surrey, UK
    There is also an 'O' ring that seals the No.8 bearing (that has the above oil seal in the end of it) to the case halves.
    You can replace the oil seal without removing the engine, but not the 'O' ring - it requires the case to be split........ so it's obviously worth doing the oil seal first, but when you do see if there is any sign that the oil is weeping from around the outside of the bearing housing as opposed from through the edge of the oil seal.
    Both will cause oil to look like it comes from behind the pulley and pool in the bottom of the motor mount.
    Mick
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    You can also have leaks at the case halves in that area that appear like they are from the pulley/#8 area
    1969 S Coupe #761
    Early S Registry #1624
