Thread: Heat on a '70T
    Mar 2005
    Heat on a '70T
    Anybody know where the heat vent is on a '70T is?
    Warm air can be directed to the lower (foot well area under the dash on either side) and upper (below windshield) by moving the slides on the dash air control unit. You would first need to pull up the red handle that sits with the emergency brake handle unit but I'm guessing you already know that.
    Mar 2005
    It's a stupid question
    Quote Originally Posted by mac73s View Post
    It's a stupid question I know. My last early car had a vent at the footwell but this car does not and my back won't allow me to look under the dash. Anyway I pulled up the red lever near the handbrake and have the all levers on the dash and I feel no heat coming from anywhere. I thought maybe the PO had closed it off like he did to the back vent on the tunnel.
    Don't suppose you have an owners manual?? For max heat at the feet,,,,heater lever at tunnel all the way up, all levers on dash all the way left. You'll notice the red dash lever when all the way left has an arrow showing the air blast will be out the vents under the dash. For max defrost red dash lever all the way right, towards arrow pointing up!
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Make sure you're heat exchangers are hooked up to the ventilation system... Obvious but sure sounds like you aren't getting anything regardless of messing with the controls
    1969 S Coupe #761
    Early S Registry #1624
