Thread: I hear there is someone here who rebuilds hoses
    Oct 2009
    Indiana
    Friends,
    I was told that there is a member who restores SWB hoses. As I understand it, he uses your fittings and creates a correct hose with new/correct material.
    Can you provide the contact info, please, so that I can talk to him/her?
    Thank you.
    Banned
    Nov 2004
    Scottsdale, AZ
    Brad Davis is your man. Top notch.
    PM for email.
    Nov 2014
    Port Orange, FL
    I took my oil hoses to a local hose shop and had them put the German fittings on some Aeroquip hose. The German stuff leaked -- the Aeroquip stuff will NEVER leak!
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    FYI,
    For later cars Brad will also supply you with the correct size cloth wrapped Cohline hose if you are up for rebuilding the lines on your own.
    Did this with my 69... I know the fittings and hose material changed a bit from SWB to LWB. Straightforward process for the early LWB cars. Just need a good vice and some hardwood to clamp the fitting.
    Here's a thread describing it for a 67S in greater detail. Note this is different material and fittings (read crimped) than what I show in the below pics:
    http://ww.early911sregistry.org/foru...-Old-Oil-Lines
    1969 S Coupe #761
    Early S Registry #1624
