Thread: 902/14
    902/14
    Working on a 69 4 speed, A, H, Q, X. The only gear chart I have shows the same as 902/0. The trans type is 902/14 with serial #50912xx. Can't find any info on this trans any help. G.led
    Oct 2008
    Burford, ON, Canada
    Magnesium case version of the 902/0 which was aluminum case.
    Dec 2011
    Victorville CA
    Isn't the 902/14 a 912 transaxle? Just asking, not a gotcha
    http://www.blueskymotorsports.com/in...id=17&Itemid=6
    Working on a 69 4 speed, A, H, Q, X... The trans type is 902/14 with serial #50912xx.
    Here is some information from the 1969 factory Spare Parts Catalogue.
    902/14, serial numbers 5091001-5099999, was the standard 912 4-speed transmission with magnesium housing for 69, optional for "Export außer USA".
    It was the mag version of the earlier 902/04 transmission with aluminum housing, serial numbers 5090001-5090462.
    It is also mentioned in the 911 Workshop Manual in volume I, page SR139 as effective for vehicle type 912 from 30 November 1968.
    Jon B.
    Vista, CA
    Thanks, spec books had nothing. G
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    1969 S Coupe #761
    Early S Registry #1624
