Thread: Door pockets change tutorial
    Hi,
    Any idea where I could find a good tutorial on how to disassemble door panels in a 70T?
    Intent is to change/fix the door pockets.
    Any hint would be appreciated.
    Thanks Olivier
    Dec 2011
    Victorville CA
    Use the search above in the top right corner
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Ed Mayo - Door panel removal
    http://www.early911sregistry.org/for...el-on-1969-911
    Remove the top bolster
    Remove the window winder
    Remove the flip out door pocket, (pull it part way out so you can undo the bungee)
    Remove the arm rest (three allen hd bolts, one sheet metal screw behind flipped down door pocket, and unclip plastic snap from inside door handle)
    Remove front bolt from front of forward storage bin
    Reach BEHIND door, through now flipped down door pocket, and find 10mm (wrench size nut) holding rear of front bin. The bin and flip down pocket can stay on door with their hinges, (unless you want them out of the way, then just remove the machine screws at the hinges)
    Now using your door panel clip tool (or a flat putty knife) pop off the door panel that is held around the perimeter with plastic snap pins.
    If the plastic moisture barrier is missing you should make a new one, protects the fiberboard door panel.
    1969 S Coupe #761
    Early S Registry #1624
    Thanks beh911 - Appreciate it ...
