Thread: Turn signal question
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I am slightly perplexed by my turn signals, of all things. On my 1969 911S the battery is fully charged and the turn signals in the front and rear of the car work fine. But the turn signal indicator arrows imbedded in the tach blink only once or twice then fade away to darkness, even though the outside turn signals continue to function normally. Any thoughts?
    As always, many thanks!
    Alan
    New Jersey
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Dear Alan,
    try changing the fuse first
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    I imagine it's the turn signal relay in trunk, up behind the instruments.
    1969 S Coupe #761
    Early S Registry #1624
    Apr 2004
    35,000 ft
    Mine will do this at idle but under full revs, all is good, so I expect it's a bit of a charging issue but more likely a less-than-ideal grounding situation.
    Apr 2003
    New Jersey
    Haul hit the nail on the head...I checked fuse #8 and it was corroded. I cleaned it up and the turn signals work perfectly! Took all of 60 seconds.
    This forum is amazing...special thanks to Haul.
    Alan
    New Jersey
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
