Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Replacement Batteries
    Senior Member jloucks388's Avatar
    Oct 2006
    Walnut Creek, CA
    For a '72 with a dual battery setup, what's the best solution for new batteries?
    -Jim
    '72 911T
    '02 B5 S4 (RS4 Clone)
    '12 997.2 Turbo Manual
    '19 B9 RS5 (Daily)
    Apr 2004
    35,000 ft
    The correct ones are interstate u911, but gel-mat batteries for a Miata work out pretty well, slightly smaller, and you really can get by with just one.
    Aug 2005
    VA
    Drive the car to Batteries Plus or some other battery store and see what fits. Otherwise, mail order a pair of the U911's. Susquasian (sp?) makes a gell battery that fits perfectly. Mine only lasted a couple years so not my recommendation.
    Chris
    73 E
    Oct 2010
    Southern Ca.
    Sonnenschein batteries . They have lasted for years in my car . Ed Mayo likes them which I think is a good reference .
    PS : I would not put a container of sulfuric acid in my early Porsche .
    Oct 2010
    Florida
    I've had good luck with the U911 batteries from Interstate.
    The batteries from Porsche? Not so much.
    Richard Newton
    Car Tech Stuff
    Exactly the same experience............
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    6 years, 3 months and going strong, on my current Porsche batteries...
    1969 S Coupe #761
    Early S Registry #1624
    Jun 2012
    London, Ontario, Canada
    My Porsche batteries were charged, but then sat at the restorers for 4 years. Charged them up again and vroom, vroom. Perfectly healthy.
    Ravi
    Early 911S Registry # 2395
    Quote Originally Posted by Richy View Post
    Did those, they cost an arm and a leg... Seem to be good ! One morning I came back to them completely discharged after a cold night. To this day no idea what happened... I thought they were toast but nope, took a charge and been juicing ever since.. Note that they're a very tight fit re: connectors contacting the battery box w/o insulation. Personally - as much as I like those - next time I'm buying cheaper ones that are a little smaller for comfort over bumps !
    Greg.
    72 911T - 73 2002
    #1461
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    I just purchased a pair of Interstate 911 batteries this past Spring. Strongly recommend you hook up your batteries to a battery tender, as I have done.
    Brent
    '70 911S
    '68 TR250
