Results 1 to 10 of 20
Thread: Engine Cooling Fan bolt/Nut
    Dec 2013
    Connecticut/Florida
    Perhaps a silly question, but the bolt in the picture below looks like its short and that the nut is only holding the fan on by a few threads. Is this unusual?
    1971 911S Coupe - Gemini Blue
    Sure is, should be nearly flush
    Dec 2013
    Connecticut/Florida
    Thanks. It is tight, so not sure what's going on. Car does have AC
    Fan is binding on the key on the alt shaft. It is caught, so key is hung up and not seated. Remove the pulley and fan and fix the key. Hopefully the fan/key are not buggered up. This would have also caused a misalignment of the fan and crank pulleys.
    registry# 1283
    Jul 2011
    Chicago Area
    I have the same issue, my alternator was rebuilt 4 years ago and I didn't notice the nut was not on all the way when I got my car back. Now with my rebuild we noticed it, is there something behind keeping the alternator from seating properly like a reversed washer/spacer or something.
    Name:  IMG_3262 (1024x768).jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Mike I wonder if you have replaced the alt. nut, looks to be thicker than the normal nut, which would make it stand further off the alt. shaft. Also there should only be 5 to 7 shims, if you have more because of belt sizing that will also force the nut out further. What size is the belt? 9.5 by 710, or 10 by 710?
    Jul 2011
    Chicago Area
    6 shims and belt is 9.5 x 710. Nut and cup washer are the same thickness as what was there genuine Porsche from Stoddard. Prior to replacement old nut was not flush either.
    Mike Fitton # 2071
    Banned
    Nov 2004
    Scottsdale, AZ
    In OP and Mike's sitch, remove the belt and shims and reinstall just the pulley half, collar, and nut. If still no threads protruding from the nut it's simple: the fan isn't seated properly on the shaft. If the key is installed properly I suspect there's a washer on the backside that shouldn't be there.
    Breath of fresh air to see an original fan Mike rather than an over-restored one.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Inhale deeply, Frank. Here's another one for you
    1969 S Coupe #761
    Early S Registry #1624
    measure the nut thickness, should be 8mm.
