Results 1 to 10 of 12
Thread: Transmission housing repair, possible?
    The Netherlands
    Hi,
    I have this bell housing but obviously it needs repair. Is this possible to repair (Mg) and is it worth it? I just have the housing, no internals.
    Kind regards,
    Cees
    Mar 2006
    Louisville KY
    Tony Proasi
    52 split window coupe
    More expensive but a complete bulkhead repair from Wevo, Alu case pictured but same for Mag. Gordon
    Quote Originally Posted by fourteenten View Post
    Cees, what are you referring to that obviously needs repair?
    The gap between the two bearing bores is normal, and the bores themselves are iron, not magnesium.
    Are the bearing shells loose in the bores? Based on the dust, dirt and rust I see in the bores, it doesn't look like bearings have been fitted recently.
    Please explain the problem.
    Jon B.
    Vista, CA
    The Netherlands
    Hi Jon,
    There is an uneven gap between the bearing bores and it is even lifted a bit up. Can't believe that that is correct. Indeed, I have it for a couple of years in my garage collecting dust and dirt. I do not see that gap in Gordon's picture.
    Thanks, cees
    Cees, the gap is normal on early cases, and it's not a problem. There are no retaining clips in this area for the bearing shells.
    If it is lifted slightly on the surface, then just dress it down.
    Gordon's is a later aluminum case and has been repaired in this area, so it is not a good comparison.
    Here is a similar magnesium case of mine...
    There are not many good photos of this area in the factory manual, but maybe you can see the gap here...
    Jon B.
    Vista, CA
    The Netherlands
    That is good news Jon, many thanks. I will check the S/N to see what year it is from.
    Best regards, Cees
    The serial number was stamped on the lowest part of that housing. Sometimes it is badly scraped, and difficult to read.
    If you cannot read the number, then take a photo of the clutch bearing guide tube. There were three different versions, only one of which was removable.
    Jon B.
    Vista, CA
    The Netherlands
    Thanks Jon, I will report back.
    Cees
    The Netherlands
    915/02
    Sorry for the late follow up. Here's a picture of the serial number. It is a 915/02 housing. Now busy cleaning it...
    Regards,
    Cees
