Results 1 to 10 of 16
Thread: 2.7 RS Spec engine from Rothsport hits the dyno
    Rothsport Racing just completed a 2.7 MFI engine for one of my latest projects.
    Here it is in all it's glory.
    Began with a 2.4 T MFI engine with the 7R case.
    Completely rebuilt/renewed.
    Sourced a set of NOS Mahle 2.7 8.5:1 pistons/cylinders.
    Webcam modified the existing cams to S/RS spec.
    Heads and valves upgraded to S/RS spec.
    Racing valve springs and Ti keepers.
    4 rib oil pump
    Stoddard high efficiency oil cooler
    Carrera pressure fed chain tensioners
    Obviously all new gaskets, seals, etc.
    MFI pump rebuilt and upgraded by MFI Werks (Mark Jung) to 2.7 RS spec.
    Plastic velocity stacks bored out to correct ID.
    Throttle bodies upgraded to S/RS spec by Burnham Performance; also they recurved the distributor to RS.
    Pertronix magnetic points were added.
    High output ignition coil and matching solid state CDI box from Partsklassic.
    Damon Series 900 amber fan shroud.
    Mark Motshagen refinished fan/fan housing.
    Clewett spark plug wires.
    Customized 914-6 engine sheet metal....clue where the engine is destined to reside.
    1-5/8" headers
    Single outlet Dansk sport exhaust.
    Majority of the re-plating handled by Shaun at Tru-6.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
    1973.5 911T
    Dyno run on Facebook:
    https://www.facebook.com/doug.skinne...type=3&theater
    Engine made 224.8 peak hp with 190 ft-lb torque.
    Well in line with factory figures.
    Engine starts up on a dime and has a very nice idle.
    The sport exhaust sounds awesome as the engine revs to redline.
    A "well done" to Jeff Gamroth, Scott and the rest of the engine building crew at Rothsport.
    -Doug
    1973.5 911T
    Sep 2013
    Vancouver, WA
    Might try that Facebook link again. It's not producing anything for me. I'd like to see the engine run.
    A bit of history.
    Original condition of engine.
    Was sourced from Australia.
    Teardown showed a nice mouse nest on top of the cylinders.
    Maybe he got frequent flyer miles from the big trip across the pond?
    Everything disassembled by me, boxed up and ready to head to Rothsport's shop late last summer.
    -Doug
    1973.5 911T
    Quote Originally Posted by Gearby View Post
    Put the link back on there.
    It works for me....
    https://www.facebook.com/doug.skinne...5325515166638/
    -Doug
    1973.5 911T
    Sep 2016
    Hamburg, Germany
    Link is not working for me either.
    But the engine at least looks great!
    Christian
    I'll get it on Vimeo in the morning.
    -Doug
    1973.5 911T
    Here's a couple of videos on Vimeo.
    1st is the engine running about 2000rpm, running it in, and checking each spark plug as to timing. Found that with the Pertronix, a couple of the cylinders were off
    a bit. A degree advanced or retarded. Not sure if we'll try to get a better manufactured Pertronix rotor or not. Doesn't seem to affect the performance of the engine.
    https://vimeo.com/253575134?utm_sour...campaign=28749
    2nd of the dyho run.
    https://vimeo.com/253574791?utm_sour...campaign=28749
    Hope these video links work better than the Facebook one....
    -Doug
    1973.5 911T
    so very sweet......
    headers look very sexy .......brand?
    Quote Originally Posted by 70tangerine View Post
    so very sweet......
    Unknown, just a set Rothsport had in the shop to use on the dyno since the 914-6 HE's wouldn't fit.
    -Doug
    1973.5 911T
