Results 1 to 10 of 14
Thread: New style steering coupling
    Aug 2013
    Westlake Village, Ca.
    My old steering coupling is shot so I'm replacing it with the new style that Porsche sells. It is obvious how the original one mounts up but I'm not sure about the new style since it doesn't have a solid mount all the way through for the bolts. In other words if I use the original hardware and torque it down it just compresses the coupling. Anyone have experience with the new style? Thanks
    <img src='https://i.imgur.com/AktDBEP.jpg' />
    Scott
    303581
    Aug 2011
    Virginia Beach Va
    This is how it should look installed Name:  image.jpg
Size:  81.2 KBName:  image.jpg
    Part numbers needed
    901.347.201.00 (1)
    644.47.104 ground strap (1)
    901.347.248.00 (2) lock plate
    900.074.129.02 (4) Bolt’s
    Attach one lock plate from the bottom steering coupling 2bolts(do not forget to attach the ground wire ) from the bottom to the steering shaft. Before tightening it up slide the top lock plate
    Through the steering Shaft. Torque to spec. Secure lock straps
    Then attach the top bolts(do not forget the other end of the ground strap)
    Torque to spec secure lock straps
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Aug 2013
    Thank you for the great photos Doug, they are very helpful.
    Scott
    303581
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    Are you missing these metal sleeves? I’m doing the same job on my oldie this winter.
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    Aug 2013
    Missing the metal sleeves??? I guess I am, were the sleeves supposed to come with the coupling?
    Scott
    303581
    Jan 2013
    Shenandoah Valley
    Mine did. I purchased from Sierra Madre. Brand is JORG.
    I haven't installed it yet so I don't actually know how it goes together, but the metal sleeves fit perfectly over the bolts.
    Alex in Virginia
    Looking for:
    Aug 2011
    Virginia Beach Va
    Yes I did forget to mention the metal sleeves
    If I remember They came with the part from Porsche.
    Did you get your parts from a Porsche dealer?
    Doug Lehman
    Member #2825
    1966 912
    Aug 2013
    Yes I bought it at my local Porsche dealer. So you're saying it should've come with the sleeves?
    Scott
    303581
    Aug 2011
    Virginia Beach Va
    I bought mine from Sunset Porsche in OR. I know I have them. Installed. I will check to see if I still have my old one.
    Doug Lehman
    Member #2825
    1966 912
    Aug 2011
    Virginia Beach Va
    the sleeves 100% should have come with the part.
    Doug Lehman
    Member #2825
    1966 912
