Results 1 to 7 of 7
Thread: Oil filter
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Oil filter
    Billie Basic Question.
    What brand of oil filter do most of you use??
    MY72
    Limited choice here in New Zealand and they are probably not manufactured where they say they are on the box.
    Thanks in advance
    Mark
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Mark
    I’ve been using the newish Porsche branded oil filter on both my 72 and 73. If you want a few of those I’d be happy to figure out shipping to NZ and send them your way.
    Nick
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    May 2009
    Wellington, New Zealand
    Hi Mark,
    We used to import Mahle filters but a few years ago BNT stores (should be one near you) started stocking Hengst filters. 100% happy so far with fitting Hengst - We probably fit 10 or so per day to various modern cars at the shop.
    I think your car would need an h17w27.
    If you'd prefer Mahle, The metric nut in CHCH seems to list OC54's in stock for $30
    http://www.themetricnut.co.nz/shop/i...&product_id=77
    Cheers
    Reuben
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Mann OC-54 for 40 yearsr....but I’d never pay $30 for one. I must’ve purchased my last supply many years ago. Still have a few left.
    I have been using WIX oil filters
    73 911S Targa
    Dec 2008
    Black Mountain, NC
    I like the Canton Racing filter, this one has anti flow back so not to drain your filter into the tank on the 911 and good quick start up pressure, 8 micron filtration flows 45 gpm A bit pricy to start with but filter elements are very reasonable buying the 6 pack I use the std version on the 912's without the anti flow back as I don't have them inverted like the 911 mounting, as ref the Ferrari has the filter on the top of the motor with mounting flange down.
    https://www.cantonracingproducts.com...on&key=25-464F
    Edit, pricing is better from Summit racing or Jegs and usually free shipping
    Feb 2017
    Auckland NZ
    Thank you all for the responses
    Mark
