Results 1 to 9 of 9
Thread: Correct faceplate
    Correct faceplate
    Is this the correct faceplate for the early 911's
    What year?
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    69-71 but it is a Repro
    Quote Originally Posted by dirk07 View Post
    Are they different from Original?
    Apr 2016
    Stuttgart, Germany
    Is the left end of the basketwave cut straight or folded like the right.
    For the cutouts and the structure one may only guess from your picture if they are right or not
Size:  115.8 KBName:  s-l16003.jpg
    Jul 2011
    Chicago Area
    Looks right to me, here is an original smooth vinyl one I just sold. With the larger circular holes it should take the chrome trim piece with the recessed center bar that installs from the front.
Size:  125.7 KBName:  RecessedTrim.jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Jul 2006
    Switzerland
    I agee with Dirk, originals had edges cut straight. And with time, (at least) Basketweave shrunk, exposing a little bit the metal it was glued on. As on my car.
    This above looks Repro and edges are folded/glued, which imo never was done so in period.
    Registry member No.773
    Jul 2011
    Chicago Area
    Quote Originally Posted by 911T1971 View Post
    Right side of the faceplate was folded over here is the back of an original faceplate pictured above. Same thing on my '71 Targa basket weave.
    Here are examples of factory installed radios and you can see that the right side of the faceplate has the material folded over. If your material doesn't fold over the right side it was probably dealer installed or material was changed out.
Size:  64.3 KBName:  radio2.jpg
    Mike Fitton # 2071
