Results 1 to 9 of 9
Thread: 3.0 Engine low power problem
    Hi all, hope I can pick some brains!
    I have on the bench a 3.0SC motor, RSR mahle 95mm high comp pistons, SC heads, ported, compression ratio works out around 10.1-1, DC80 cams, high butterlfy MFI. Single plug, tuned length headers and a rear box with no internals.
    Engine makes 200 hp on a dyno with a big flat spot at 5000rpm, pulling my hair out with it, could it be an exhaust issue? Or inlet? Or just a bad missmatch?
    Initially thought low compression with a 90cc SC head but ratio is up. Pump has been re-done.
    I'm tempted to fit a set of carbs and standard SSI set up to see if I get any better results? !
    Cheers in advance.
    Hmmm... I'll let the pros weigh in... however if you're in my state of CA at 10.1 with single plug, you may be run'n into an octane issue... just say'n
    We'll see what the pros say...
    Good luck,
    cm
    Who did the pump, and to what spec? Gordon
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    2nd that
    Flat from 5k to ?? or just flat from 5000
    Mark
    And you've checked your total ignition advance ?
    Banned
    Nov 2004
    Scottsdale, AZ
    Please post the dyno sheet otherwise this whole exercise is a comedy routine.
    Thanks.
    Jan 2016
    Bad Münstereifel--Germany
    DC 80???? The Konfiguration is mayby not perfekt? Take vor this a S Cam.....
    Broken valve spring??
    Banned
    Nov 2004
    Scottsdale, AZ
    Still waiting for dyno sheet.
    I do hope the OP updates his post. Nothing more frustrating than someone seeking free advice then disappearing. When that happens one can only assume someone was stupid and embarrassment soon followed.
