Thread: FS: SWB NOS Vent Windows/Frames
    1. Two left with clear glass with lever assembly
    2. One right with clear glass & 68 protective rubber cover on lever (can be easily removed for early cars)
    NLA each + shipping & fees Jim cha;_saeng_gin@hotmail.com
    Jim
    Too many Porsches and one VW are starting to fill up my desert landscape.
    https://www.instagram.com/1967s_307184s/
    Aug 2009
    SF Bay Area
    Jim said "2. One right with clear glass & 68 protective rubber cover on lever (can be easily removed for early cars)"
    Not so fast.........All you will accomplish by removing the rubber is destroy a rare lever. The metal part of that lever is no where near what a "early" lever looks like. The post at the bottom is also different from an "early" car. and uses a different clamp to hold it to the vent frame.
    Warmest Regards
    Jim
    OK, my error, can not remove the rubberized cover. Thank you for the input Jim B.
    Jim
