Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: source for fuel vent line
    On the euro early 911's, and some U.S. cars there is a fuel tank overflow box located underneath the front cowl on the drivers side. It's about 4-5 inches square. At the bottom there are 2 nipples. One is 9mm and the other 15MM. The 15 mm goes directly to the tank. the 9mm is the actual vent to outside.
    The 9mm hose is available from the dealer, the 15mm is NLA. I am looking for the correct 15mm ID hose that is fuel vapor compliant.
    I found a old post that said SM had it in stock. I called them and it was 16mm instead of 15mm they have, which would probably work. Then I asked if it was fuel vapor compliant. Silence on the phone. Then the salesperson said they would be willing to check with others and give me a answer and call back within 15-20 minutes. No call. So I assume they don't have it, or don't know.
    You can go to Home Depot and buy what appears to be the real deal, but not fuel compliant. Being the 15 mm off the tank, a full tank will splash a little gas up the hose. Over a short time, the hose will start to melt. I googled the manufacture of the German dealer 9mm hose and they do have a U.S distributor. But, their online catalog showed hose only up to 10mm, and 100 meter rolls.
    If anyone has some sensible thoughts, please share your source.
    We get it from Mcmaster Carr, it is fuel vapor rated, and is yellow in color. I know, not quite the correct amber, but at least not clear.
    Thanks for the reply Ed. Yea, I saw that but was looking for more original if possible, which I don't think is going to happen, so I might go with that. Also, I think you have to go with inch size,as the metric only went to 10 mm.
    And, if you read product description it says not compatible with ethanol based fuels. But, in this application where gas is rarely going in the tube, I think it will work fine.
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Rick
    I used the McMaster yellow vapor resistant tubing as Ed suggests. Better than the clear IMO. Lame iPhone photo:
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    May 2006
    CT
    Rick
    I purchased the tubing for my ‘70E project from McMaster Carr.
    5187K75 Fuel and Lubricant Yellow PVC Tubing 1/2" ID, 5/8" OD, 1/16" Wall Thickness
    5187K68 Fuel and Lubricant Yellow PVC Tubing 5/8" ID, 7/8" OD, 1/8" Wall Thickness
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Nick's tank seems to have a 9mm nipple so he was able to use the hose with 1/16 wall. Tom , the 5/8 stuff has a wall thickness of 1/8. Looks very bulky and non original. Yes, it will work fine. My application is a vintage race car with no trunk carpet so when the hood opens the heavy hose sticks out like a sore thumb.
    So Ed, knowing the correct hose is NLA, would you "ding" someone at a event you were judging ?
    Yes,,,,you would have to, because you have to give someone with correct original full points,,,,,but I would deduct more if the hose was clear I need to see what we're using for the larger hose, seems like we started with the thicker wall but then went to the thinner wall because it looked better.
    McMaster here and the cute little "blue fabric" covered lines off the master cylinder.
    This tank never rusts.
    Early S Registry #235
    rgruppe #111
    Mar 2006
    Solana Beach, CA
    That’s a clean and tidy trunk Tom, as it should be.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Thanks, Nick.
    rgruppe #111
