Results 1 to 2 of 2
Thread: 1972 911 11 Blade Fan
    Junior Member
    Sep 2017
    New Zealand
    Yes it will fit, but it is a late model fan and needs matching pulley 1/2. Twin plug motor has fan in question and single plug motor has correct fan with large holes. Late set up will work with a 9.5x700 belt because fan hub is a little smaller. Correct fan with large holes has a hub that is a little larger and would use normal belt 9.5x710 belt.
