Thread: 3 liter case differences
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    What are the main differences between a 76-77 3.0 liter turbo case (930/53) and a standard early 911 SC case, like the 78-80? Also, do both use the same 70.4 crank?
    Nick
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Trusting to memory here Nick, I think the 76-77 aluminum cases still used the main bearing size and 6 bolt flywheel from the first generation engines. 78 and up started the 9 bolt flywheels and larger main diameters. I'm sure some one will verify or correct
    Mar 2006
    Solana Beach, CA
    Thanks Ed, I think that’s correct regarding the 6 bolt flywheel being used on the early turbo case.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Yup. Crankshaft...6 bolt 75-77 3.0L cases ... 9-bolt 78 and later.
    -Marco
    TLG Auto: Website
