Can anyone help?
I want to fit sway bar ball pins in the swb trailing arms which I already have.
The trailing arms are of the car
I have got Porsche drawings of the modification with some dimensions, which are good, but only give me 2 reference points from the spring plate attachment face.
The problem I have is knowing where to mark out the correct rotational position on the arm.
I have attached a couple of images with yellow lines showing the 2 measurements I am looking for.
Regards,
Jim.Name:  T01.jpg
Size:  208.2 KBName:  T00.jpg
