Thread: Wurth underbody shutz not thick enough?
    Wondering if anyone has had similar experiences with the Wurth underbody shutz being a bit too fine and not as thick and "pebbly" as it should be to get the original look. Despite going a few different ways, we're still not getting it quite spot-on yet. Curious if this is the norm given what's available out there. Any thoughts appreciated.
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i do have the würth materials and the würth gun but i don`t use it anymore (only for the sand paper look on the inside of the trunk lid on early reutter built swb--i add sand blast bedia to it) for the reason you mentioned..i did a lot of testing to get different looks but i found the repeatability not given.i think there is to much solvent in it and when it evaporates the structure that first looked great gets lost when dried up
    i now use material called innotec and also there gun...and i`m very happy with this stuff.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by haul View Post
    adheseal,Spray-Seal HS-m and Spray-Seal LS-m. available in 3 colours and different viscosity
