Thread: electrical question
    Aug 2010
    Colorado
    electrical question
    I have a 67 912. My wipers and turn signals aren't working. The lights work and I can go from high to low beam. My horn works. The lighter works. The warning lights work.
    I restored the front suspension. If the ground strap at the steering box was left off would this cause my issue? What else could cause this issue?
    Chris Pomares
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Just use a jumper wire and ground the switch to good ground, if they start working you have your answer. Lack of power, start at the fuse box and work your way to the switch, checking for voltage at every connection along the way.
    Aug 2010
    Colorado
    Thanks Ed.
    Chris
    www.reSeeWorks.com
