Results 1 to 8 of 8
Thread: Correct mfi hose?
    Dec 2008
    Toledo, Ohio
    Correct mfi hose?
    I have spent some time searching for the correct hose that runs between the heat exchanger and the engine tin then on to the mfi thermostat, it is a very thick rubber, maybe barrier hose. The new replacements seem to be silver foil. Anyone have a source for the correct thing? Pic for reference.Name:  DF8268E2-1845-4A91-8B0C-14E7907B079B.jpg
    Lightbulb
    What you need is called a 'Steam Hose', I couldn't find it at Stoddard or Sierra Madre, but I found it on Amazon:
    https://www.amazon.com/Porsche-Heate.../dp/B00AGZIJHA
    Hope this helps,
    cm
    Dec 2008
    Toledo, Ohio
    Interesting, I was doing some searches earlier for barrier hose and I remember seeing some that said steam hose. I will look into this, Thanks.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    It's not the same hose as the paper and foil combo that connects above the tin to the pump thermostat as you are finding out.
    See post 62 here, where I took a picture of the steam hose on a factory restored 73T with MFI
    http://www.early911sregistry.org/for...l=1#post524829
    1969 S Coupe #761
    Early S Registry #1624
    Dec 2008
    Toledo, Ohio
    Yea, the pic I posted is my old hose, just wasn’t sure what it was exactly or where to get it new.
    Oct 2010
    Southern Ca.
    The correct hose is available from Porsche , or Napa has a similar steam hose , I think 1 inch .The hose will be less money from the dealer .
    I brought my original into an industrial hose supplier and he was able to match it pretty easily.
    1969 911 E #824
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    It has part number 000.043.205.21. Seen here as part #27:
    Thomas
    1973 911S Targa
