Thread: Question for the driving light experts
    Aug 2010
    Colorado
    We have these driving lights hooked up to relays. They fry a 20 amp fuse. So far they seem to work with a 25 amp fuse. What level of fuse do these lights need?
    If the car looks a little funny it's because the fenders and bumper are just loosely attached.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Senior Member TurkisTii's Avatar
    Feb 2012
    Chicago, IL
    What's the output of the driving lights? Assume 150 Watts each for 300 Watts total power consumption... 300W@12v is drawing 25 Amps.
    Early 911S Registry #3811
    '70 911S Coupe Tangerine
    Instagram @turkis.tii
    Dec 2010
    Southold, NY
    What gauge wire are you using to supply power to those lights?
    Aug 2010
    Colorado
    14G
    The lights are 100W.
    www.reSeeWorks.com
    Feb 2012
    Chicago, IL
    Chris, that's 200W total so unless you are getting a voltage drop at or below 10V under load you shouldn't be blowing the 20 Amp fuse. 200/12=16.67 Amps
    Have you measured the voltage?
