Results 1 to 9 of 9
Thread: FS: 1970 2.2 911T engine w/ ‘68 transmission
    I have a '70 911engine ready to be plugged into your project. It is 2.2l with correct Zenith carbs, complete with everything except a muffler. I have a video of the engine starting and running smoothly. Receipts for work done. No smoke on start up, no leaks. Compression test shows 160 psi (+_5psi) on every cylinder. The package includes the '68 5 speed transmission (#3282631). Happy to assist with shipping. Would split up if necessary. Project went another direction. $16.5k or offer
    Info on the engine number? We have an extensive lost & found thread and yours may be a match. GLWS
    Peter Kane
    '72 911S Targa
    Right, I can post it in the morning. Thanks
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    i have a 1969 missing engine and transmission. Curious to know the number.
    www.tcspeed.com
    The engine number is 6106894 I hope that helps
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by PDQ356 View Post
    6106894 is a 1970 2.2 911T engine
    davep, you are correct, my error. Thanks for catching that. '69 would've been a 2.0l, and this is a 2.2l
    Sep 2020
    Long Island, NY
    Apologies - but I am also curious on the 1968 transmission. Would you mind posting the transmission number too? Thanks!!
    Transmission number is 3282631
    Thanks for the interest
