Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Correct Seatbelts 1968
  1. #11
    Aug 2009
    SF Bay Area
    Quote Originally Posted by dmaddox View Post
    Thank you for the information! Looks like I know what I need now. What mejia_anthony posted. What is odd, is that I don't have that anchor point for the over shoulder piece. I looked in my wheel wells and they were either welded shut and undercoated YEARS ago....or were just lap belts.
    My car was US delivered (to New Jersey), left the factory 10/67, delivered to new owner 3/68. Nothing on my Kardex that refers to seatbelts/restraints.
    You are probably looking in the wrong place. Just under the rear quarter windows. Your car may have been reupholstered and they are covered up by incorrect upholstery. You cant see them from the wheel wells. You will also have harness mounts under the rear package shelf upholstery. Your car definitely had shoulder belt anchors. If it had some shoddy rust repair, they may have been eliminated.
    Jim from Sunny, rust free, California
  2. #12
    Sep 2020
    Long Island, NY
    Well, looks like it has been reupholstered and covered up. Yet another project! I'll work on finding the seatbelts first.
    Looking for a 1967 911S Project!
    My 78 FJ40 Build
  3. #13
    Dec 2010
    Southold, NY
    I know this thread pertains to 1968 cars, but I am curious when Porsche switched to the lapbelt/harness combination anchored on the seat frame and "B" pillar. Attached is a picture of a Karmann coupe completed December 4, 1968. Was the change made after the factory's August holiday with the introduction of the LWB cars? Were any SWBs made after the holiday?
  4. #14
    Three Point Seatbelt Mountings
    The 1965-1967 (short wheel base) cars had the attachment point under the side rear window as shown in the first 2 photo below - car interior.
    As a comparison the inner fender metal housing photo (as seen from the wheel well) shows the oval shaped metal receiver used in 1965 thru 1967 cars.
    The lower rectangle shape (drawn in) would be where the 1969 Retractable Seatbelt Take-up Real mounting point is located.
    Look up into the fender and see what your car has for metal mounts (No need to pull the interior out to verify).
    Bob
    Early S Reg #370
  5. #15
    Sep 2020
    Long Island, NY
    Well.....damn. In the "3 Point Seatbelt Mounting Points" photo you show above - I, indeed, have that oval shaped "SWB mount" - however, its ripped out and covered with metal from what appears to be the interior. @##$$!!!
    I see I can order this: https://www.stoddard.com/sic80312321...12321-set.html
    Is that correct for the SWB cars? I noticed in some 68 911L's they had a hoop anchor point as opposed to this "button" style, if you will. I am handy with a welder....but I have to say, this is going to be a bit of a bugger.....and it won't be the same oval cup you see in the above photo unless I have a couple of donor chunks to work with.
    It's all coming together.....
    Thank you, Bob, for the insight.
    My 78 FJ40 Build
  6. #16
    Aug 2019
    Belgium
    I have this seatbelts, i would consider a sale
  7. #17
    Sep 2020
    Long Island, NY
    Thank you Gunbab, I was able to secure a set of correct belts from another member here. Thank you!! Now, I just need to solve for the wonky plug thats covering the attachment points shown above. Ugh.
    My 78 FJ40 Build
  8. #18
    As far as I know, the shoulder belt bolts switched over in MY67 from Chassis Number 30 8091 to the hex head bolts. So any MY 68 with a Chassis Number of 118 x xxxx would have the hex head bolts.
    Inside the oval-shaped sheet metal part that is missing from your car is a 7/16-20 threaded boss.
  9. #19
    Aug 2009
    SF Bay Area
    Quote Originally Posted by ejboyd5 View Post
    That car is a 69YM and a LWB.
    Jim
  10. #20
    Dec 2010
    Southold, NY
    That car is a 69YM and a LWB. Jim
    Of course it is a '69 LWB. I've had it since 1978. My question was whether any SWB cars were completed after the August holiday.
