Results 1 to 7 of 7
Thread: Paint tags
    Jun 2013
    lynchburg, Va
    Paint tags
    Best way to remove and install the riveted paint ID plate?? Without harming paint.
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
    Sep 2020
    Long Island, NY
    Outside of using a small drill and drilling out the rivets carefully and then re-riveting in, I'm not sure there is another way to preserve both the tag and the paint.
    Looking for a 1967 911S Project!
    My 78 FJ40 Build
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    this is how i do it
    Sep 2020
    Long Island, NY
    Great work Moito - and a steady hand, too! Have you tried just drilling out the rivets with like a 2mm drill bit or whatever size the hole is and then punching? This is how I have removed tags on other vehicles. Just curious!
    My 78 FJ40 Build
    May 2013
    Victoria BC Canada
    The shop that did the body and paint on my 911, (Jetstream Restorations) drilled 4 small holes through the opposite side of the door post and used a pin lunch to tap the rivets out, preserving the near perfect original tag and rivets. They welded up the small holes they drilled afterward. I thought it was a smart solution.
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by dmaddox View Post
    yes i did the "drill a hole" but that was to easy.
    never did the "drill a hole and punch from the other side"....but sound like an idea ...i`d assume one hole is enough
    Porsche 914's have a good size hole that allows you to tap out the 4 rivet screws from behind.
    Guessing you're not as lucky with the 911?
    One of the 1st things that always gets my attention is a painted over or chewed up paint tag.....I just hate the way it looks.
    So to me, it is very important to somehow remove the original paint tag in one piece without damaging it before repainting the door jam area.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
