Thread: FS: Rear extended jack points
    Aug 2010
    Colorado
    I've used these on Rebel S Racing 935 Spring Plates and Rebel's greaseless rear spring plate bushings. I've just had a small run made (6 sets) and have 2 sets left. They are aluminum and will need to be welded on and slightly clearanced at the front inside edge, When the car is on the lift there are no worries about damaging the seam on the pan or having to use the rear sway bar mount.
    $150.00 plus shipping and Paypal.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Aug 2010
    Colorado
    These would probably work on 935 type spring plates made by other companies.
    www.reSeeWorks.com
    Aug 2010
    Colorado
    I made 6 pairs and have sold 4 pairs so far.
    www.reSeeWorks.com
