Thread: Zenith mods for upgraded 2.2T
    Apr 2011
    Central Florida
    I'm restoring my '71T and I am now rebuilding the upgraded the 2.2. I've researched the modifications needed for the Zenith 40TIN carbs, but have seen varying recommendations. Parsing all the data, this is what I've come up with. I welcome suggestions.
    Use: Primarily street driven, with autocross or track day several time a year; looking for a broad torque curve, rather than max horsepower.
    Engine: 2.2, cylinders bored to 85 mm for a 2.3l; JE pistons that give a calculated 9.7:1 compression ratio; Solex cams; 7200 rpm max.
    Zenith Carbs:
    venturi: 32mm (stock is 27.5)
    main jet: 135 (stock is 115)
    idle jets: 55 (stock is 475)
    air correction jets: 160 (stock is 195)
    idle air bleeds: 110 (stock is 165)
    Thank you for your input!
    dho
    dho
    Central Florida
    Member # 1968
    Looks good to me. You will want to test for mixture strength for optimization so idle air bleeds from 90 through 110 would be handy to have, main air correction may be a tad small, perhaps a 170. However, your starting setup is close enough to enjoy without fear or major tweaks being required.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Apr 2011
    Central Florida
    Thank you, Paul. I value your input and appreciate the way you share your knowledge and expertise.
    dho
    dho
    Central Florida
    Member # 1968
    Dec 2009
    Copenhagen, Denmark
    DHO, where do you get zenith parts from?
    James Hurst #1638
    R Gruppe #514
    You can buy Zeniths parts from eBay, seek the seller "Alfa1750"
    Paul Abbott
    Early S Member #18
    530.520.5816
    Apr 2011
    Central Florida
    Yes, to Alfa1750 on eBay for parts-specify the size of jets in the comments to Seller at checkout. Excellent customer service.
    dho
    dho
    Central Florida
    Member # 1968
