Results 1 to 9 of 9
Thread: Liquid chrome ?
    Apr 2012
    Simi Valley Ca
    Liquid chrome ?
    Found this at Hobby Lobby. Anyone ever use this on light housings? Kinda hard to get an even cote with the small applicator, but if it was in a small bottle you may be able to get an even application with a small paint brush. The pics are of an old VW backup light that i had sitting around. Also, "Made in Germany".
    Aug 2017
    el sobrante ca.
    maybe open it and put it in an air brush
    Looks like old silver Testors plastic car model paint.
    Peter Kane
    '72 911S Targa
    Dec 2013
    Connecticut/Florida
    Rust oleum is ok, not great but better than nothing
    1971 911S Coupe - Gemini Blue
    Jul 2018
    Syracuse NY
    I just used some metallic tape
    Nov 2010
    Darien, CT
    Write up on using liquid chrome out of an airbrush. It's for scale modeling but still informative. Looks like the user took a liquid chrome pen apart and sprayed it as Bob suggested.
    https://scalemodelpodcast.com/molotow-liquid-chrome/
    69 911S #1379
    65 356 SC #130757
    Sep 2012
    Colorado
    I have used chrome paint on SWB tail-light housings, and it came out great. But you need to start with a smooth surface. Yours is not.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Aug 2020
    SF Bay Area
    as an aside...I have experimented with using chrome powdercoat. The problem is that the pot metal (?) of the housings off gasses at any elevated temp. I tried to pre-heat them numerous times to pre-outgas, but the bubbles still form when you heat cure the powder. The finish is excellent and reflective, but if you take the lens off the housing, there are bubbles in the finish.
    Here is a new piece of aluminum I tested on -- no bubbles. The housings just didn't work well due to the outgassing during the cure phase. Stick with the paint, which can be removed at a later date more easily.
    - 1969 911T Ossi Blue #3981
    Jul 2011
    Chicago Area
    Quote Originally Posted by gbone99 View Post
    Will the tape melt?
    Mike Fitton # 2071
    2018 911S Carrera White
