Results 1 to 7 of 7
Thread: spark plug tool
    Jun 2011
    Bellingham, WA
    spark plug tool
    I am changing plugs and using the Klein #21 tool that is from the tool kit. After loosening the plug, it falls out of the socket. Is there a way to reuvvinate the rubber holder. Or maybe its pushed in too far
    You would be better off to get a magnetic spark plug socket.
    Dec 2010
    Southold, NY
    Factory supplied tools are best reserved for show and for only the most dire of emergency use. Purchase decent tools for real life maintenance and repairs.
    Jun 2011
    Bellingham, WA
    Ed, which socket and extension do you recomend?
    Senior Member McOtto's Avatar
    Apr 2023
    Denver, CO
    Ed likely has a better recommendation, but I use this one. Articulated, securely holds the spark plug, and readily available for a reasonable price at your local auto parts store.
    https://shop.advanceautoparts.com/p/...47d/11970577-P
    Dec 2010
    Southold, NY
    I've used the Gear Wrench P/N 80547 with no difficulties.
    There is a gentleman named Paul Bernardo who I believe is located in Nevada who makes a reproduction spark plug tool that looks and operates essentially like an original Klein.
    I have purchased 2 of them in the past and they are great for the tool box or a slip into a tool kit that is missing and original.
    He also makes very nice reproduction red screw driver sets for both 65-68 and 69-72 cars.
    His number is 702-398-3972
    1969 911T Coupe Blood Orange (Vivy)
