Thread: Incorrect distributor question 2.4S
    Junior Member
    Jun 2012
    Austin TX
    Greetings
    Starting to clean the distributor (too HOT to do much else in Tx) and It appears I have an incorrect distributor installed for a 2.4S engine. The installed distributor is : 0 231 184 001 which I believe is appropriate for a 74 2.7 CIS.
    I believe the spec distributor is 0 231 169 005 (010).
    What are differences in advance curves, implications between 184 vs 169?
    Also, I am trying to remove points plate to clean weights etc, I know I am supposed to turn plate 1/4 turn CCW and it should lift out.
    It rotates freely CCW but then stops and looks like it still needs to rotate a bit more prior to being to lift it up.
    advice?
    Charles
    Did you remove the cap hold down clips.
    Junior Member
    Jun 2012
    Austin TX
    Yep, screws were out
    Plate rotated smoothly to almost 1/4 turn then got tight
    More force applied and it rotated to where it cleared detects and came out
    Junior Member
    Jun 2012
    Austin TX
    Having removed points plate I see on a post that holds the high tension spring, the plastic bit that the spring nests in is broken.
    I have not found that the part is available - OK to run as is?
