Thread: Oil hose(s) specs
    Dec 2003
    West Los Angeles
    Oil hose(s) specs
    Working on 2 911s... One with 26mm fittings and one with 30mm fittings
    I have cut 30mm rubber hose and the i.d. is 20mm. I do not have cut 26mm rubber hose, and want to know i.d. -- logically it should be 16mm.
    Can anyone confirm?
    Seems smooth finish rubber hose is hard to get in metric sizes, so will likely be adapting US hoses...
    techweenie.com
    Mar 2017
    Orange County, CA & Tucson, AZ
    Hopefully Brad Davis can chime in here
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
    Thanks Bill!
    Hi TechWeenie,
    I have both smooth wall and wrap cured German oil hose. Will be happy to supply however much you would like. The smooth wall hose was not introduced until late 70s.
    Are the lines you are working with crimped or assembled TCH fittings? Also what year car are you working with?
    Hoses vary quite a bit depending on manufacturer. What I typically see are these sizes:
    DN16 - ID 18mm
    DN20 - ID 22mm
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Dec 2003
    West Los Angeles
    PM sent.
    techweenie.com
