Results 1 to 9 of 9
Thread: 2 stages rear window defroster switch wiring
    hello,
    can someone help me with the wiring for my 2 stage rear window defrosting switch ?
    here is a picture of the switch
    Attachment 598627
    which color on A, B, C or D ?
    missing is the small bulb to light the switch on center, so I have 5 wires to put on ?
    I have 3 brown together, and a black with a grey also together.
    but I think the grey and the black should be separate, but what are the other wires I need ?
    Attachment 598628
    thanks for any help
    frederic Name:  IMG_9611[2].jpg
Size:  141.7 KBName:  IMG_0359[1] copy.jpg
    Jun 2012
    London, Ontario, Canada
    See if this post is helpful. https://www.early911sregistry.org/fo...=1#post1029255
    Mine is a '73S. If not, I can pull the switch and take a picture.
    Ravi
    Early 911S Registry # 2395
    1973 Porsche 911S in Light Ivory 5sp MT
    2023 Porsche Macan GTS in Gentian Blue 7sp PDK
    hello,
    seen your post, if you can take a full picture would be lovely
    TIA
    fred
    since you have it all apart...you may want to install the rubber grommets that went into the holes in the dash and sealed the switch...wasn't really much of a seal..but it kept the air from coming into the cabin
    Jun 2012
    Quote Originally Posted by carrera79 View Post
    hello,
    TIA
    fred
    Apologies, I’ve been doing some travelling. Will take a pic in the next few days.
    thanks for help
    Feb 2012
    Kolham, Groningen, The Netherlands.
    The letters are a bit confusing but i think:
    A , marked 3 on switch ? - Jumper to C + single black ,from tunnel harness
    B, marked 4 on switch ? - White black (from tunnel harness)
    C, marked 2 on switch ? - See A
    D, marked 1 on switch ? - Double black (from main harness)
    The spade terminal on the bulb holder gets a brown wire (3 x)
    I think it's the right switch. I don't know if the photo will help you much!
