Thread: WTB: Automatic Heat Control wiring harness 91161215200
    Junior Member
    Mar 2014
    Hello
    I'm attempting to restore a complete Automatic Heat Control system on my car removed by one of the previous owners.
    I need a wiring harness running from the front fuse panel to the control unit in the tunnel #10 on the reference diagram.
    Can anyone help?
    Marcin
    Junior Member
    Dec 2023
    Maryland
    Marcin, I expect by now you have found a source for this harness, but if you have not, a good source for quality Porsche harnesses is Kroon.
    I am considering replacing my same harness, but not quite sure how much work is involved, perhaps you could assist having gone through it, I assume.
    - 3 conductor plug goes to auto heat control
    - bare conductor & loop connector to front fuse panel
    - remaining two wires, I am not sure where they terminate, plus, what are these two wire colors?
    Thanks for any assistance with this, Marcin.
    - John
    May 2006
    CT
    I might have that harness. What year is the 911 you need this for?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
