Thread: Blank case engine stamp 2.3/2.7
    Oct 2011
    California
    I purchased a non running 1968 with a blank case engine. It has been stamped 2.3/2.7 in the sequence number and engine type area.
    Has anyone seen this before? .
    Just trying to figure out what I have here. Name:  IMG_3436.jpeg
Size:  119.9 KBName:  IMG_3435.jpg
    Oct 2008
    Burford, ON, Canada
    Okay, so a Mag case, but which version xR numbers (both sides please) form the casting # under the oil return tube locations.
    The 2.3/2.7 would appear to be the engine sizes it was built to at various times. What was the combination when you took it apart? A 2.3 would be a special performance combination but the 2.7 could be nothing special.
    Oct 2011
    California
    Thanks Dave. I will get those casting numbers and post them.
    The engine is still complete and turning over. What is inside is a mystery.
    Oct 2011
    California
    Just getting back in town and had a chance to get the casting numbers from the engine.
    901.101.101.3R
    901.101.102.3R
    Oct 2008
    Burford, ON, Canada
    That case combo was prevalent during much of the 1971 model year.
    I believe the only way to solve your mystery is to disassemble it.
