Thread: 906 Cams original
    Member RockhillMtr's Avatar
    Apr 2023
    Tomball, TX
    906 Cams original
    Very clean original part number set of 906 centerlube cams, not regrinds, no refurb needed. Lobes are all very nice, as are the bearing journals. Not a chip, nick, scratch or wear on them. Journals all mic out to within a tenth of a thou of each other. Included is the special 41mm fine thread nuts and washers. Centerlube holes in each end have been plugged for spray bar use, however I assume those could be removed if using for centerlube application. I do have a MFI drive adapter for the left cam if one wishes to use them in an MFI motor. The cams are a bit blotchy darker gray color in some areas but this appears merely cosmetic.
    $1650 plus PP fees and shipping.
    Apr 2023
    Tomball, TX
    Nice original cams for your hotrod or race build.
    Apr 2023
    Tomball, TX
    Original 906 cams still available
    Apr 2023
    Tomball, TX
    $1200 for this set of original 906 cams.
    Apr 2023
    Tomball, TX
    Nice set of original cams still available
