Results 1 to 10 of 13
Thread: Muffler Paint Question Revisited
    At one point Stoddard offered a high temp muffler spray paint. Unfortunately, that product is no longer available. What high temp muffler paint is presently available for the early 911s that is a close match for the original paint color?
    Dec 2013
    Connecticut/Florida
    I like VHT flat light grey
    1971 911S Coupe - Gemini Blue
    Quote Originally Posted by prs356 View Post
    We use Wurth zinc. It is exactly what the factory used originally to paint the mufflers
    Is this what you're talking about dr ?
    https://www.pelicanparts.com/More_In...8aAoo7EALw_wcB
    Chuck Stoddard referred me to VHT SP-104 and I have been using it for 40 yrs, always with good results, it is light gray.
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by dr914 View Post
    I have an original ‘73 date code Leistritz muffler in original paint and it is definitely not a metallic finish.
    Can you expand on your statement? I also doubt that the factory painted the mufflers. Likely they came prefinished from the suppliers.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Somewhere on here somebody posted an original muffler picture. I think the consensus was that they only painted the part that could be seen looking from the rear. Can't find the post.
    I've also been using VHT SP-104 with good results.....it's very close in color to the original.
    JEFF BRINTON
    ESR #1572
    1968 911N
    2018 991.2 Carrera T
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman / 1974 914 2.0L
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by doigthom View Post
    You know at first I thought ‘no way, why would they do that?’ So, went back through the pictures of the 700 mile S and sure as scheisse,,, Two colors on the muffler. A light grey like what’s on my ‘73 dated muffler and then a sloppy half in a darker grey. Could be the zinc as mentioned so, my apologies! As for the straps, I bet only part of them were painted along with the less than half of the muffler.
    https://www.flickr.com/photos/807244...7630169538658/
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Oct 2010
    Southern Ca.
    The VHT SP-104 is really too light and too blue , but there are no other options . A color like the Wurth zinc was definitely used on the early 911's through the mid 1970 MY . This is one thing that is wrong so often people think the wrong is correct , the early exhaust was not grey .
    Look at period factory pictures .
