Is there a part number for this plate?
Any one has 1-3 if NLA?
Richard
Richard
the arrow is pointing to the wrong spot---this thingie goes to the two screws on the rear of the frame...and if i remember correctly bolt size changed early in production so if someone offers you one make sure it is the correct one---will have a look what i`v in stock... hmm `...now i`m not even sure if your car should have it at all--will have a look for reference pictures.
You are correct. What was I thinking??
I can not find the plates while the doors have been taken apart and I didn’t get it from the metal guy.
Still I would need one for my preS because on that car they definitely went down.
Other question I posted which you might have missed
Ignore the plating, the yellow one (spare) is the early one, but do I need the other hardware too (might be at the painter but can not find it on my pictures).
Last as a “bonus”. During your restorations did you “spot” these 3 different versions?
Richard
i noticed 3 different versions of the flap but the way the cable is secured (center flap) is new to me
i`m positiv that i do have the wanted hardwear...let you know later this week.
f.
I have the plate you posted in the very first picture. They go on the rear of the door as Moito said. They are NLA.
72S, 72 3.5L Signal Green, 914-6 GT Signal Green
I could need one of the nice rubber flaps....mine is deteriorated and the rubber reconstruction is not as precise as I had hoped..
https://www.912bbs.org/forum/threads...6/#post-467114
the middle flap is a repair - schraubnippel..
I can recommend to swap for the reenforced version, since the first version will bend and break...sooner or later..
btw. the wire part is available at porsche classic parts - 901.571.071.20 - also the wire routing.
if yours is not bend, I would strongly recommend to replace it, as any deformation of the wire results in a "hard-to-move" in the wire routing -
honestly: i am hoping Porsche Classic will do the flap..
59 750 pre unit triton
65 912 slate gray "erwin"
73 914 ravennagreen "ferdl", swapped 1:1 for a
10 997 racing green awd „gustl“
erwin_loves_polo
