Thread: 2.0 S MFI - Headers/Muffler require fuel adjustment?
    Hi all - relatively new to the MFI world, so apologies if this question has been discussed elsewhere. I'm considering changing out my SSI H/E's for a set of equal-length tubular headers and swapping the current Dansk sport muffler with something else. The motor is a 2.0 S with MFI pump (serial ending in 005) and runs great.
    Will adding a freer-flowing exhaust create drivability issues or should I expect to have to retune the MFI pump?
    Will eliminating the warm air flow to the MFI pump cause warm-up issues?
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Since your considering this and your engine runs great, in my opinion I would leave it as is with your SSI H/E's and sport muffler. Reason I say this is because I have run a few tests on a dyno over the years and found with a 2.0 MFI engine there is a loss of low end torque when using certain equal-length headers. And with the loss of your warm air thermostat you will have to fabricate a cold start system. Not a hard thing to fab but with these changes I don't really see a big leap in performance gain.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Very helpful. It's already fairly anemic below 5k, so might be best to leave well enough alone.
    You might want to check for full throttle,,,,might be surprised!
