Thread: 73.5 CIS injectors needed
    The 73.5 cars have a unique fuel injectors for that year only. Only source seems to be dealer at almost $300 each! I called and stock in Germany only and a month to get them. Has anyone found away around this expensive problem? Car sat for 25 years. I did ultrasonic cleaning and then a good douching with an injector cleaning pump machine. To far gone. Anyone who has a way around this please speak. (Or type)
    May 2014
    South East USA
    Have you tried the samba
    There is a place that restores them too. Are you sure they can't be saved? I don't recall the place. I'll have to see if I can find it.
    I did find this. I have no idea if it is any good: https://rennlist.com/forums/928-foru...injectors.html He uses a tweezers and string to pull the injector open so it can fully clean. I don't know what he does about the screen.
    This place seems to have multiple suggestions: https://www.injector.com/cart/pc/home.asp
