Thread: What happened to the felt window guide channels & soft originals?
    Guys
    See photos , I show the original material for U channels NLA and supposed replacement from Porsche
    Originals 911 542 901 00 (top piece ) & 911 542 902 (vertical front & rear )
    Now 911 542 905 for all ( its segmented ,rubber & plastic)
    Am I correct….. I finished one side I had material for & tried to get same material
    This what the new material is …?
    Does anyone have enough of the old style for coupe door channel ?
Size:  57.6 KBName:  485109CF-E3EB-4DAC-9577-C8A1628BE73E.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Have you tried International Mercantile?
    Jul 2006
    Corvallis, OR
    The new single piece from Porsche works just fine. I start in the corners and pop them in first then just snap it in all the way around. You'll see how snaps in on both sides of the U channel.
    72S, 72 3.5L Signal Green, 914-6 GT Signal Green
    Guess I would be ok with new versions but have one side already done…. frame mounted and fitted
    Good thought to try International Mercantile
    How smooth is the new version?
    Thanks guys
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
