Thread: Headliner "Hold-down" Strips
    Hi All - I've posted this to our brethren on pelican.....
    I am about to install a new headliner in a 1970 coupe. I would like to find a source and or a part no. for these strips:
    Name:  Headliner Hold-down Strips.jpg
    They appear to be constructed from a type of cardboard/paper material.
    Dims: 29mm (1 1/8") wide x 2.4mm (3/32") thick x 280mm (11") long. They are located at the base of
    the "C" pillar where the headliner transitions to a contact area under the parcel shelf cover They were
    originally held in place by spiral nails (?). I believe some form of sheet metal screw as a viable replacement
    for the nails would be a logical upgrade. Any help or advice is appreciated.
    Thanks in advance.
    Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    Jul 2006
    Corvallis, OR
    They're not totally necessary but if you want to use them you need to make your own or reuse old ones. I don't think they're available.
    72S, 72 3.5L Signal Green, 914-6 GT Signal Green
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Longballa View Post
    exactly even the factory did use them only when needed...there is also a steel rod version of it. both shown here
    https://www.early911sregistry.org/fo...ight=roofliner
    your old ones could be brought back into shape by butting them in an hot/ humid environment for some time and once they are shapeable simply flatten them(press between two flat boards) and let them dry
    I ended up using an old steam iron to flatten them out & they appear to be serviceable. Any suggestions as to any form of further pre-installation treatment (such as a varnish, epoxy, or shellac) to give them a tad more rigidity?
    Thanks Gents & Cheers
    JB
