Results 1 to 2 of 2
Thread: Window lift Rail- issues 1971 Coupe
    No issues with DS but After several hours wrestling with PS door glass installation I could not get the glass to slide on nylon rollers?
    They seemed to engage in the track but wouldn’t slide on the track…
    Took glass and crank our of door
    More investigation and measurement the channel is 11- 11.5mm ? measured my installed DS and the channel is 12mm …
    Then checked Part numbers - 65-69 (90154204621) is different then 70-73 (90154204623)
    Not sure but seems the channel dimension changed maybe other aspects a well…
    My glass/wlifts came from several suppliers as used ( needed good glass ) so perhaps the one I used
    Came from 69 or earlier
    Anyone else have this issue ….
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Turns out the channel had bends at various point and mostly the first 1” after engagement..
    Solved and slides correctly…on the the window frame install hope hoes as smooth as DS
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
