Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: MFI Throttle Linkage - Obstructed by Fuel Line
    Hi all,
    I have a '69 E that's had its numbers matching motor built to S spec (with corresponding "005" MFI pump). The car runs great as far as I can tell (first early 911 for me) but I did notice that the throttle linkage for cylinder 2 is impacting the fuel line below. From what I can gather, it looks like this is at or near the throttle stop so I don't *think* I'm missing any additional throttle travel, but I can't be sure. I also really don't want to begin messing with the linkages.
    Any thoughts? Can this be dialed out by adjusting the throttle cable at the pedal and/or elsewhere on the car?
    Thanks.
    Jul 2003
    Santa Cruz, CA
    Your injector lines have been jacked with IMO. I started the tear down of my 70S lump recently. Here’s a shot before I tore down the injection.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Dec 2013
    Connecticut/Florida
    Or is the connection lever on in reverse ?
    1971 911S Coupe - Gemini Blue
    Incorrect fuel lines.
    photo flipped
    Got'cha covered David ...
    thanks Chuck
    Oct 2010
    Southern Ca.
    You guys are clueless , the fuel lines are correct for a '69 , and yes the linkage is reversed or wrong position .
    The picture is of the throttle depressed to 100% to illustrate the contact between the linkage and fuel line. Is the linkage actually backwards?
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by Richy View Post
    Interesting.
    Is there a technical reason for the seemingly stupid routing in 69 or did they just have to deal with overly long lines?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
